selbekk 0 Posted April 20, 2006 My motor has begun to tick. Now, it's not really bad, like sierras, but it still sounds like my car is old and crappy, which is isn't! (well, at least not crappy) What does this sound mean? it's not even there all the time, it comes and goes. Any ideas? Quote Share this post Link to post Share on other sites
**stan** 0 Posted April 20, 2006 I once had a similar thing with an old scirocco. Spent around 80 quid on new tappets. Still ticking! ARRRGGGHHH. Bought new camshaft £120. STILL TICKING AAAARRRRGHHHH!!! Turned out it was the cambelt tensioner £9. Mine was also intermintant. Would recommend checking here first! Basically work in the opposite direction to me, much cheaper!! Quote Share this post Link to post Share on other sites
steve_16v 0 Posted April 20, 2006 was expecting you to say "tick BOOM!" there... anyway, like **stan** says do the cheap stuff first like the tensioner, and change the oil & filter if it hasn't been done recently Quote Share this post Link to post Share on other sites
selbekk 0 Posted April 20, 2006 hehe nah the engine is actually sounding great! the cambelt tensioner, is that the spring assembly by the alternator? and what is tappets? since I'm norwegian and all ;) Quote Share this post Link to post Share on other sites
**stan** 0 Posted April 20, 2006 Hydraulic thingies! Sometimes called cam followers. These are round things that sit on top of the valves that the cam lobes run on. The cambelt tensioner can be found under the cambelt cover (plastic thing next to the rocker cover on the right hand side of your block). This is usually held in place by some clips and quite easy to remove. The tensioner looks like a pulley wheel and is approx 100mm in diameter on an eccentric cam for adjustment. Quote Share this post Link to post Share on other sites
selbekk 0 Posted April 20, 2006 ok. so what's the spring thing on the left side then? Quote Share this post Link to post Share on other sites
**stan** 0 Posted April 20, 2006 Would assume it's something to do with either waterpump, altenator or charger etc, but having never had a go at g60 lump I couldn't give you an absolute answer. Sorry you said left side didn't you? Are we talking left side stood infront of car head in bonnet??? Quote Share this post Link to post Share on other sites
**stan** 0 Posted April 20, 2006 Not a clue then. I know theres alot of pipe work in that area for the intake system, but not having a g60 I don't think I can help any further. Good luck though. Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted April 20, 2006 ok. so what's the spring thing on the left side then? What that looks like a shock absorber??? If that is it then its the charger belt tensioner. Takes up slack on the looping path of the belt. The cam belt tensioner is below the can sprocket. Where the belt dips in and rounds a small pulley wheel. It has an offset nut two small holes. The above is if your not taking the P**** :lol: Quote Share this post Link to post Share on other sites
selbekk 0 Posted April 20, 2006 hehe I wasn't taking no piss, 2_Door_fun, I am just ignorant. Thx for clearing that up for me :) I'll try changing the oil first, once I get around to it. Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted April 21, 2006 hehe I wasn't taking no piss, 2_Door_fun, I am just ignorant. Thx for clearing that up for me :) I'll try changing the oil first, once I get around to it. Here ya go. Always a good start to yr knowledge. Not a bad site as a whole either G60 underhood Corrado club Canada Quote Share this post Link to post Share on other sites
_leon_ 0 Posted April 21, 2006 that 'spring thing' is very expensive - about £70 from vag... Quote Share this post Link to post Share on other sites
zacon 0 Posted July 12, 2006 My engine started ticking on the way home from work last week. I noticed my oil level was somewhat low, so I refilled a little, without improvement. The next morning it was fine, but started ticking again after around 20 kilometers. My engine seems to start ticking every time it gets hot. (It actually has to be hot a little while.) This seems to happen regularly. I changed the oil a couple of months ago, using a 10W40 oil. It's a 2.0l 16V (9A) engine. Quote Share this post Link to post Share on other sites
