BlackHeartValentine
Are Corrados Able To Run On E85??
Are Corrados Able To Run On E85?? E85 is 109 octane fuel produced through Alcohol 60% of cars are already equipped to run on that, but I was wondering cause gas is soooo expensive and E85 is more efficent in everyway, burns cooler, way less carbon build up, etc...and the kicker, You Can Make It Yourself! So, all I wanted to really know is Are Corrados Able To Run On E85??
Modifications to run on other fuels usually involves injector differences, iirc. In principle, *petrol* that was 109 RON should work ok (though the ECU might be a little bit out of range with it's fuelling calculations), but something vastly different from the physical properties of petrol might not atomise correctly or flow correctly through the injectors, so at the very least you would need a remap doing, at the most you'd need a whole new fuelling system installed.
Can't be more specific, cos I've not looked at the details...
