Stan 24v 0 Posted April 21, 2006 Has anyone got any wiring diagrams for 1994 VR ABS? Apparently the one in the Bentley isnt the correct type A) because its american B) because the pump used on the VR wasnt used for long. I have an ABS light on my car, and the VAG com says the signal is out of tolerance. All sensors have been replaced to try and clear the fault, but to no avail, hence the need for the diagrams. Cheers 8) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 21, 2006 You looked at the pedal position sensor as well as the wheel sensors? Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted April 21, 2006 You looked at the pedal position sensor as well as the wheel sensors? Elaborate please sir?! If its related to accelerator pedal, thne yes it could be the cause, but if its brake pedal, then nothing has changed, but obviously that doesnt rule it out. Im not too sure if he has checked that?? :roll: Quote Share this post Link to post Share on other sites
bigpants baby 0 Posted April 22, 2006 on the brake servo,little plunger with 2 wires coming from it Quote Share this post Link to post Share on other sites
