.A.N.T. 0 Posted April 25, 2006 Hi, I've noticed a rattley noise coming from the front end somewhere for quite a while now. Also the wheels rotate (when jacked up) forward and backward quite a way whilst in gear. prob total movement is about 1hr on a clockface My mates 16v doesn't do this, his wheels won't move at all when in gear. This makes me think that something is worn/loose in the transmission area. Any ideas what? It's done 180k and is still on it's 1st gearbox. Could that be it? Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted April 25, 2006 im seriously interested in this as mine moves abit when up in the air and in gear Quote Share this post Link to post Share on other sites
dub envy 0 Posted April 25, 2006 My front wheels were moving back and forth loads when on the rolling road... worn front bushes. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 25, 2006 I think he means rotating on the driveshafts, not that the wheel hub is moving at all. And yes, it's pretty normal for a high-ish miles car to show some (significant) slop in the drivetrain. That's what the sagittal clutch plate springs are for - to damp the action when the clutch takes up the slop. The noises are another thing. Most likely wheel bearings. Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted April 25, 2006 dr mat so would replacng the clutch make his problem better Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 25, 2006 Errrrm, no... The clutch doesn't remove the slop, it simply damps the shunt that occurs when you apply drive. Quote Share this post Link to post Share on other sites
.A.N.T. 0 Posted April 26, 2006 I've replaced the clutch about 20-30k ago when I did the engine swop, and the wheel bearing were done about a month or two ago. If the play is 'supposed' to be there then that isn't so bad, but I don't like the rattly noise when driving as it's clearly audiable from people on pavements... "oh look, there goes that rattley black corrado again..." Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted April 26, 2006 does it rattle the whole time or just under brakeing? Quote Share this post Link to post Share on other sites
