sikaa1 0 Posted May 1, 2006 Hi Guys, Just had my corrado plugged to VAG-COM (due to the ABS warning light coming on intermittenly)and came out with the attahed codes. Can anyone out there explain them in plain english. I've also had the two front brake sensors changed recently and it hasn't made a difference. Light still comes on when I'm driving. Goes off on start-up after 5secs and comes on / off whilist driving................HELP!!!! Cheers, Sika Here are the faults from VAG COM Monday, 01 May 2006, 12:34:55 VAG-COM Version: Release 409.1-S Control Module Part Number: 1H0 907 379 Component and/or Version: ABS Software Coding: Work Shop Code: 4 Faults Found: 00285 - ABS Wheel Speed Sensor: Front Right (G45) 35-00 - - 00285 - ABS Wheel Speed Sensor: Front Right (G45) 16-00 - Signal Outside Specifications 00285 - ABS Wheel Speed Sensor: Front Right (G45) 04-00 - Mechanical Malfunction 00793 - Brake Pedal Position Sensor (G100) Quote Share this post Link to post Share on other sites
bigpants baby 0 Posted May 1, 2006 00793 - Brake Pedal Position Sensor (G100) thats on your brake servo (near the bottom,there is a plunger type switch) Quote Share this post Link to post Share on other sites
buttles 0 Posted May 1, 2006 Hi, did you clear the codes and re-scan after changing the sensors? You might find the sensor error has gone. Welcome and good luck! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 1, 2006 Yeah clear them as they may not have been cleared when the sensor was fitted - if it comes back then check it's plugged in... Quote Share this post Link to post Share on other sites
sikaa1 0 Posted May 1, 2006 Hi Guys, Thanks for your advice. Just a few more things! Supercharged - I suppose it will have to be plugged back into VAG-COM to clear the fault codes? Bigpants baby - How easy is to replace/sort the brake pedal position sensor? 16-00 Signal Outside Specifications 04-00 Mechanical Mulfunction Are these related to the two above? Cheers, Sikaa1 Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 1, 2006 Yep, clear them first before going any further... you'll need to drive it until the light comes back on and rescan... The BPPS is fairly easy to change but awkward to get to, you need a mirror to see how to unclip the circlip but then it;s just a straight swap - about £50 from VW. Quote Share this post Link to post Share on other sites
sikaa1 0 Posted May 2, 2006 My local VW dealer reckons the BPPS is the same as the brake light switch. I need to be sure b 4 I start swapping. Any ideas? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 2, 2006 Change your dealer! Don't buy anything before you've cleared the codes and waited for the light to come back on. Quote Share this post Link to post Share on other sites
sikaa1 0 Posted May 9, 2006 Supercharged, cleared the codes over the weekend. Light still coming on. Still reading 1 fault - 00285 - ABS Wheel Speed Sensor: Front Right (G45) Changed the two front sensors about a month ago when I got the first reading. Any ideas??!!! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 9, 2006 Unplug the sensor wires at the top of the suspension turrets and measure resistance and compare with each other... does the light come on before the car moves? - if so may be a connection problem Quote Share this post Link to post Share on other sites
sikaa1 0 Posted May 10, 2006 The light comes on when the ignition is switched on for about 5 secs and goes off - as per normal. It only comes back on and off when the car is moving. i.e. Normal on ignition/startup, problem starts only when the car is in motion. Quote Share this post Link to post Share on other sites
kerrinmay 0 Posted May 10, 2006 I has a similar problem with mine where it kept coming on intermittently and it turned out to be the brake pedal sensor. I've now got a different problem when sometimes I start the car and the light just doesn't go out at all, stays on the complete journey. Annoyingly, my C apparently is of the type that doesn't hold it's fault codes and so I've never been able to get the fault diagnosed and it never seems to occur when I take it to a garage. Is VAG-COM a hand held device or something linked into an actual PC? I could really do with something portable that I can carry around with me, and then when the fault occurs I could just plug it in. Is VAG-COM expensive to purchase? Where could I purchase one from? Quote Share this post Link to post Share on other sites
kerrinmay 0 Posted May 10, 2006 Just found this on ebay - will this work for an early '92 model do you think? http://cgi.ebay.co.uk/VAG-COM-OBD2-DIAG ... dZViewItem Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 10, 2006 sikaa1 said: The light comes on when the ignition is switched on for about 5 secs and goes off - as per normal. It only comes back on and off when the car is moving. i.e. Normal on ignition/startup, problem starts only when the car is in motion. In that case it could be a rusty or distorted abs rotor (the part that the sensor looks at) if the sensor is ok... Kerrinmay - check out http://www.vagcom.co.uk Quote Share this post Link to post Share on other sites
kerrinmay 0 Posted May 10, 2006 Supercharged said: Kerrinmay - check out http://www.vagcom.co.uk Thanks - just took a look at that site. Now searching for a cheaper one on ebay, as can't really justify the £240 ish amount just to check out an intermittent fault. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 10, 2006 There are generic code readers available for £15-25. They'll just report the error code though, usually, you'll have to look it up in a book to translate that back to what the fault really is. Quote Share this post Link to post Share on other sites
kerrinmay 0 Posted May 10, 2006 Where can I get a £15-£25 generic code reader from? And what would be a name to look for? Also, is it possible to download a list of all fault codes from somewhere? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 11, 2006 I think they sell 'em in Halfords and other auto factors. Couldn't tell you a name, I didn't buy one, some research on google might do the trick though.. :) Quote Share this post Link to post Share on other sites
sikaa1 0 Posted May 11, 2006 Supercharged: Can you determine the level of distortion and corrosion on the abs rotor cage? Is it fairly straight foward to replace? And another thing? ABS light only started playing up after I had the discs and pads changed!! Cheers, Sikaa Quote Share this post Link to post Share on other sites
sikaa1 0 Posted May 11, 2006 Supercharged : Is there a way of detecting a faulty cage or is it just a visual check? Are they easy to replace? Cheers, Sikaa1 Quote Share this post Link to post Share on other sites
sikaa1 0 Posted May 29, 2006 Supercharged - "the plot thickens" ............................ Spent hours changing the abs rotor and wheel bearing and deleted all fault codes.........it hasn't made a blind bit of difference. Light goes off after approx 5 secs on start -up (every time) and comes on whilst the car is in motion. VAG-COM is telling us it's the drivers' side sensor..........Can't be (hopefully) a faulty connection because it goes off on start up (every time). Sensors, abs rotor and wheel bearings have been changed....... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 29, 2006 Hello - sorry only just saw this... BTW Kerrinmay - The generic code readers are £9.99 in halfords at the moment but they are faily cack compared to vagcom and not even sure if they report ABS fauls - they also only come with pins not a proper OBD2 plug... sikaa1, try unplugging the abs connectors at the top of the suspension turrets and measureing resistance accross them - compare one side to the other and report back... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 29, 2006 sikaa1, have yo still got vag com - can you post up what fault you are now getting - ie what is says underneath the code Quote Share this post Link to post Share on other sites
