localhost.80 0 Posted May 2, 2006 I remember driving my car(1990 Corrado g60) on the freeway when I decided to speed, it was ok from 65mph to 95mph till when it I tried to go faster it wouldn't go passed that, like if it was locked out or something. Quote Share this post Link to post Share on other sites
localhost.80 0 Posted May 2, 2006 Here are something I already done and working on. Replaced O2 Sensor Replaced Intercooler Lower Tube. Replaced Throttle Position Sensor Replaced Temp Sensor Replaced Speedometer cable Replaced CAT Replaced Fuel Filter Replaced Fuel Pump Replaced Fuel Injectors Replaced Fan relay *Working on Timing idle screw fuel pump sensor Quote Share this post Link to post Share on other sites
Riley 0 Posted May 2, 2006 having looked at your other thread concerning your ignition timing,id be inclined to think thatll sort it m8 8) replace the idle screw. sort ignition timing by eye/and then with a timing light,and it should be good i reckon. neil. :) Quote Share this post Link to post Share on other sites
localhost.80 0 Posted May 2, 2006 thanks, maybe I should fix that first and then complain. :D Quote Share this post Link to post Share on other sites
localhost.80 0 Posted May 2, 2006 just one more thing, Sorry How do you install the fuel pump(Tank) correctly? Quote Share this post Link to post Share on other sites
localhost.80 0 Posted May 3, 2006 One more thing :oops: there is a little tiny bitty hole in my intercooler lower tube. what should I repair it with? Quote Share this post Link to post Share on other sites
Riley 0 Posted May 3, 2006 no probs m8! thats what the forums here for :D as far as i know the in tank pump just twists in and out... as for the pin hole in the cooler tube,needs a new hose really,that wont be helping performance either! neil. :) Quote Share this post Link to post Share on other sites
localhost.80 0 Posted May 3, 2006 huh, really because I remember I replaced my fuel pump and the sensor is screwed up or something, because on my cluster the fuel guage go up and down like a roller coaster, when I press on the gas. Quote Share this post Link to post Share on other sites
