g60bv 0 Posted May 10, 2006 i need to make new markings on the pullies so i can set up my timimg. i have a few problems. i 'm running tooth belts which dont have the markings on. so if i can get the fly wheel to tdc i can put a bit of tip ex on it. but on the fly wheel there are 2 mark one tdc and one 6'. which one is tdc. taking the wheel as turning anti clock wise. is it the first or second mark. any help. ta Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 10, 2006 Best way to do it is find the middle of the dwell angle on piston 1 at TDC. Pop a long thin bit of wood or a screw driver in the plug hole to rest on the piston. Now back the crank back and forth and somewhere in the middle of where the piston neither moves up nor down is your TDC, and the bell housing pointer should then be pointing at the right marker. Quote Share this post Link to post Share on other sites
g60bv 0 Posted May 11, 2006 i'v got the cylinder head off. so i can see it. but its only 6' , the piston bearly moves. Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted May 11, 2006 im not sure as its been a whils since my 8v days what markes you got, its a v shaped notch and a 0 isnt it? Quote Share this post Link to post Share on other sites
g60bv 0 Posted May 12, 2006 the flywheel has been lightned. so all i have is l l it must be the first line. if the wheel spins anti clock wise tdc would be first then the 6' mark. i only need to sure. so i can put tipex on the tooth belt. that way i can set up the timimg correctly. any one got a spare fly wheel kicking about in the garage to check it. Quote Share this post Link to post Share on other sites
g60bv 0 Posted May 12, 2006 all is ok. it is the first mark. nobody panic Quote Share this post Link to post Share on other sites
jezzaG60 0 Posted May 13, 2006 Looking from the flywheel side of the engine.... turning the flywheel anti-clockwise.... its the SECOND mark. The first one is 6 degrees BEFORE TDC. Quote Share this post Link to post Share on other sites
