kop10320178
blown head gasket
hi
got a 94 vr6 rado
head gasket is goin
had atest done and there is exhaust gases in the coolant expansion tank
it is not losing power or coolant
do i need 2 change the head gasket yet ?
and also the timing chain is worn do i get them done the same time?
can anyone one recomend a garage in the north west? ?
once head gasket is replaced will it run as good as before?
thanx jay
or should i part ex it for v6 4motion
probably if you dont want to do any damage to your engine
awesome gti in warrington, dubsport in wigan, stealth in coventry
should do
depends on how much you wanna spend i reckon, what you expect to sell your car for and the cost of the work
hope this helps and you get your car sorted with minimal of hassle
ben
A chap in Stoke (http://www.stokevwspares.co.uk) did my chains. He can do them for a very competitive price: £250 labour to change the chains and clutch or about £250 including parts. He'll probably charge another £150 to do the headgasket so about £700 for everything at a guess which is a pretty good price.
