Eug001
Moding 2.0 corrado
I have a 1993 2.0l 16v corrado, its a good car but not much go, so I would like to give it some go but not down the full rebuild route
I have been told that a good exhaust with cat bypass pipe with a good airfilter on the induction side will make a reasonable performance upgrade accompanied with a golf 16valve inlet cam?? is this correct?? what are the difference's with camshafts?
I have also found that there are different size inlet manifolds 40mm, 42mm, 50mm, what size is fitted to the corrado??
Any info would be a help
Cheers
http://the-corrado.net/.archive/forum/viewtopic. ... hlight=cam
have a look at this.... and do a search for KR cam on here. its been discussed a million times!!!
I have a standard 2ltr with the KR cam fitted and a Jetex air filter and I get 158bhp, never got round to doing the cat bypass though, dunno if its worth it now with the MOT regulations that are in force....
HTH
A cam change on a valver can be done in a couple of hours, but you must be confident in setting up the timing marks correctly. If you get these wrong you risk pistons hitting the valves - big damage + big money = big pain in the arse.
I've tried with and without the cat, I eventually sold my cat bypass and kept the cat.
