CorradoDriver 0 Posted May 12, 2006 Hey Im still having some problems with my radiator. It works but it doesnt go on by itslef, as of now it is wired 2 the battery but i have no idea why it doesnt go on. I check the fuse underneith the steering column and it seems fine (30 amp) Now i dont know why it doesnt turn on itself. There is a small box with 2 fuses a 20 amp and a 5 amp aswell as some sort of metal connector. The 20 amp fuse was blown so i replaced but still no luck Please help Share this post Link to post Share on other sites
sciroccotune 0 Posted May 12, 2006 are we talking about the fan here? is so the fan switch in on the bottom right of the rad (as you look at the car) most likely just needs replacing... Share this post Link to post Share on other sites
dinkus 10 Posted May 12, 2006 It could well be a gammy temp sendor (or 2) - have a search for 'radiator AND fan' or similar and you'll get quite a few good bits of advice :D Share this post Link to post Share on other sites
CorradoDriver 0 Posted May 13, 2006 Okay iv located the thermo switch but im not sure how to take it out and how to check if its bad. I have found some online but i do not know what temperature i should get is 102 okay or should it be less between 85-95 degrees C. I found this one online have a look http://www.evwparts.com/Merchant2/merch ... adoCooling Would this be good for my 92 slc vr6 corrado?? Thanks for the help guys Share this post Link to post Share on other sites
VR6 0 Posted May 13, 2006 Could you keep related problems in one thread please? So far there's about 4 of your threads on this or an extremely similar problem. Thanks http://the-corrado.net/.archive/forum/viewtopic. ... highlight= http://the-corrado.net/.archive/forum/viewtopic. ... highlight= http://the-corrado.net/.archive/forum/viewtopic. ... highlight= http://the-corrado.net/.archive/forum/viewtopic. ... highlight= Share this post Link to post Share on other sites
