m3evo
Loose wires please identify
20030223image00011hx.jpg Hi, Hope the photo comes out ok, this is of some loose wires at the back of the engine, drivers side from a plug with four wires going to it, there are two that are loose one black and one purple colour, anybody know what there for, many thanks Dave
Lambda Probe connection!!!
You'll definatly need to repair that as is one of the main sensors for the ECU and will make your car run rich and use lots of fuel
the purple one needs fixing
but the black one just goes into that side of the connector with nothing on the other side
the black/earth does run through the connector,it just loops onto the 10mm nut just above in the pic.
can be fiddly to repair em,you can either chop down the round plastic parts with sidecuts or similar and then resolder the wires (tin em up well first)
or you can find another connector off pretty much any vw after 93 with good connections and splice it in.
purple one goes on outside...
neil. :)
Thanks Neil, and everybody else for the help and info, will check engine mountings etc, thanks again lads, Dave
