the punisher
Water pump, Oil pump, Chain and what else
Hi All,
I have a Corrado Vr6, been lead to belive its do about 113k
what things should consider changing as a matter of course before i use it alot...i dont want something to pack up knackering the rest of the engine which is in good working order at the moment. Off the top of my head im thinking
Water pump (slightly leaky anyways)
Oil Pump
Timing Chain (how hard to do DIY?)
Anything else.....?
Many Thanks
Joel
Welcome to the forum, have a look in the knowledge base for the timing chains guide...
There is also a good write up on changing the water pump in the latest Sprinter (the magazine of the CCGB)
Change the clutch, thermostat housing/water transfer pipe, oil cooler seals and 2 pipes which go from the transfer pipe to the oil cooler.
