Kick Up The Rs
Oil Cooler install
Have just received my Mocal oil cooler kit (& pulley and chip!) from G-Werks - excellent service I hasten to add.
Before I jump in feet first with the oil cooler install, does anybody have any pointers or links to help?
In particular cooler location, coolant draining, bleeding etc.
Also, will I need to make up any additional brackets or can I use the coolers mountings.
Many thanks
I hung mine from the slam panel just in front of the charger...
Have you got a RSR outlet and are you running the OE heat exchanger?
Yep it's standard in that respect.
I've just done a search and spotted a post from Pitstop where they also hang it from the slam panel.
Will go that route as soon as I can build up sufficient inclination & courage to get on & do the job!
