balboa
Changing sensors on a 2.9 VR6
hi peeps,,,just wondering how easy it is changing the lambda and crank sensors on a 2.9 vr6 corrado...thanks in advance
Lambda is tricky apparently. Crank sensor is easy. Both are expensive, so only do 'em if you're sure it needs done ...
