the punisher 0 Posted June 7, 2006 Hi All Done a search and looked at the knowledge base but cannot find what im looking for. Im after information on the standard fuel pump what pressure does it run at? and what GPH does it pump? im looking for a pump that will deliver 50 -60 GPH Can any recommend an external mounted upragde suitable for the VR6?? Blue holley would be ideal but not suitible for injection fuel systems Thanks Joel Quote Share this post Link to post Share on other sites
dinkus 10 Posted June 7, 2006 Not sure what GPH it does, but the standard VR fuel pumps are 4-bar and more than fine for even supercharged use. What were you planning on doing to the engine that would need an uprated fuel pump? There's a pressure regulator in the fuel rail as well, so you can't really run more than 4 bar without changing a lot of the fuel system too... Quote Share this post Link to post Share on other sites
