White2505 0 Posted June 8, 2006 I've tried a search but my ineptitude has not got a result. I have a 1.8 16v the pin has broken off the thermo switch which is located on the left hand side (when viewed from the front of the car) engine head near to the airbox. it only has one pin and shorting the wire to earth makes the single electric fan cut in. all the searches suggest the thrmoswitch is on the radiator. I don't want to order the wrong part so does anyone know what this sensor is actually called and have a part number?? thanks Andrew Quote Share this post Link to post Share on other sites
16vradge 0 Posted June 8, 2006 http://the-corrado.net/.archive/forum/viewtopic.php?p=500549#500549 /\ this thread was sat next to yours on the main page! Quote Share this post Link to post Share on other sites
White2505 0 Posted June 8, 2006 yes I read that, but THAT switch is the three pin jobbie on the bottom of the radiator (if I read correctly) not the sensor on the head. Quote Share this post Link to post Share on other sites
16vradge 0 Posted June 8, 2006 oops! :oops: :) still, you could try that switches, senders, instruments section on the GSF website. Quote Share this post Link to post Share on other sites
White2505 0 Posted June 8, 2006 No problem, I've already been there but unfortunately without knowing what the part is supposed to be called I'll ending spending money on something I don't actually need and end up re-ordering and losing time. Of course being a corrado there's ALWAYS a long list of things I actually DO need so don't really want to buy something that at this stage I don't. :) Quote Share this post Link to post Share on other sites
16vradge 0 Posted June 8, 2006 I use a mk2 G (+16v) haynes manual for all things engine related, I don't have it to hand but it's worth getting one off egay if you don't have one. Quote Share this post Link to post Share on other sites
White2505 0 Posted June 8, 2006 checked my haynes golf manual already and that only mentions the thermoswitch on the radiator and not this second switch on the end of the head. I've temporarily bodged it with chemical metal :( to hold the tag on the sensor but don't want to rely on it as I'm doing a long journey next week and have only got the car back today after the engine rebuild and really don't want it going bang! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 8, 2006 I think this is the afterrun switch? Quote Share this post Link to post Share on other sites
White2505 0 Posted June 9, 2006 Cheers Supercharged, that makes sense, I take it it stays closed turning the fan on until the head has cooled sufficiently for the switch to open? ta Whitey Quote Share this post Link to post Share on other sites
lottysvdub 0 Posted June 9, 2006 its the coolent fan run on switch jobby that your after :D Quote Share this post Link to post Share on other sites
