Riley 0 Posted June 11, 2006 Whats involved here? G60 brakes onto a 4 stud vento? am i right in thinking that the vento (tdi btw) is on 239 set up? so therefor needs the G60 hubs as well as the obvious calipers? anything else? cheers,neil. :) Quote Share this post Link to post Share on other sites
Riley 0 Posted June 11, 2006 ok,just had a look about and seems that the vento could either have 239's or 256's... if 256's its just a case of bolting up the G60 carrier and caliper i think? just found out the vento is a 98 model also. cheers,neil. Quote Share this post Link to post Share on other sites
Riley 0 Posted June 13, 2006 bump for the above. plus,anyone got a good idea what a full front g60 brake set up is worth? and how much would be fair to charge a mate of a mate for fitting it? could do with some idea's before tommorow! neil. Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted June 14, 2006 hello mate, im not really to sure but i would say that if it was a 256 you should be fine, they just use gold mk3 parts right? (bump :D ) Quote Share this post Link to post Share on other sites
