Nick 0 Posted June 16, 2006 Or perhaps not. Just trying to get some information on fitting of a FMIC. I know this is going to seem like a stupid question, but sod it. I want to know! :oops: :lol: Thanks Shilakadaddy for pic - if its not ok, let me know and ill remove it! In order for an i/c to work, the pipes/connections are circled, correct? Whats the hole for (presumably unfinished and not left like that!) on the longest pipe? Are there any connections i cant see? It seems quite straight forward?! Too straight forward, and would like to know if im missing something or quite alot something! Thanks in advance peeps. Nick Quote Share this post Link to post Share on other sites
_leon_ 0 Posted June 16, 2006 the hole is there for the co pot. someone will fill you in on the pipework but yes from what i know they are the only ones you need to tend to. the one connecting to the throttle body is standard afaik. youll also have the issue of making the IC fit - some require cutting to squeeze in - but gwerks and jabba do ones that just fit i think still pricey to do Quote Share this post Link to post Share on other sites
