chrishill 0 Posted September 23, 2003 Will a PCD of 98 fit my 1990 16v? i know C's are PCD 100 but surely its not far off? Quote Share this post Link to post Share on other sites
Majik 0 Posted September 23, 2003 LOL if make the hole bigger in the hubs, than maybe! : :D Right the holes for a pcd 4/100 are going to be 100 mm apart now the holes on 4/98 are 98 mm apart so the 4/100 have a slightly bigger diameter, the PCD are made to precision that even a PCD 98 wont fit PCD4/100. Are you looking to fit mgf wheels or something? Quote Share this post Link to post Share on other sites
chrishill 0 Posted September 23, 2003 found these on ebay, the guys selling a fiat cinc as well, so i'm guessing they're off that....if they wont fit then i'll post the URL :D http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 2433060138 Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 23, 2003 LOL if make the hole bigger in the hubs, than maybe! : :D Right the holes for a pcd 4/100 are going to be 100 mm apart now the holes on 4/98 are 98 mm apart so the 4/100 have a slightly bigger diameter, the PCD are made to precision that even a PCD 98 wont fit PCD4/100. Are you looking to fit mgf wheels or something? And if you did 'force' them to fit, I can guarantee the resultant wheel imbalance will be unpleasant at speed. Kev Quote Share this post Link to post Share on other sites
Fine wine, Belgian chocs. 1 Posted September 23, 2003 No need to 'force' them to fit. Any decent alloy wheel dealer will be able to supply you some wobble bolts. These fit using a 'floating' washer instead of a fixed taper seat and have 1mm movement in each bolt so the 2mm difference in pcd is no problem. Most alloy wheel stockists only keep the 4/100 pcd now and fit them to Fiat/Alfa (4/98pcd) using these bolts. As long as the centre bore fits the hub perfectly or can be made to fit the hub by using spigot rings then there's no problem. Quote Share this post Link to post Share on other sites
