so1o
vr6 fan problems
Hi,
A while ago the small plug that plugs into the fan control module melted, ordered a new plug and wired it all up correctly, checked and double checked everything is fine. Replaced the control box aswell. The fans were working before this happened. Now the fans dont work, really sick and tired of trying to figure out what the problem is. Is there a way to direct them to activate them via a switch on the dashboard. The fans have three speeds, which speeds should be used?
Any help appreciated.
I have speed 3 hooked up to a dash switch, you run the switch across the black temp sender. Speed 2 can also be manually activated. Red/black wire off the radiator sender. If you want speed 1 aswell, you'll need to relay that off the red wire on the rad sender as it's direct to battery.
Speeds 2 and 3 are the only ones that are worth using anyway, especially 3!
Have you replaced the rad sender? That is usually the reason why speeds 1 and 2 won't work. Speed 3 comes on at 120 degrees, so you'll rarely ever see that in action, so best to override it with a switch.
