93corradoguy 0 Posted July 17, 2006 93 Volk Corrado VR6- Car broke down on me a month ago and i still can't figure it out. I ran a vag diagnostic on it and it shows no error messages. However, it shows my air intake temp. at -9 degrees Celsius and my coolant temp. at -49 degrees celsius. I replaced both sensors and its still not right. Oddly the water temp. reading changed to a slightly warmer temp. but still below freezing. I live in Florida and its summer and its hot so temp. reading is way way off. It refuses to start when everything is connected. If i disconnect both sensors giving me the faulty readings it will start but run/idle very poorly and shortly thereafter stall. I wouldn't make it a mile down the road. I've had the car 8 years and never had any issues with this type of thing before. I'm at the end of the road and hoping for some advice before i lose my mind. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 17, 2006 Welcome to the forum... maybe worth checking your engine and ecu earths,,, Quote Share this post Link to post Share on other sites
93corradoguy 0 Posted July 17, 2006 Thank you. It's nice to see a good active corrado forum. Engine and ecu earths? I'm not familiar with that if you could explain to me what and how to do. Quote Share this post Link to post Share on other sites
