volkswag0nvr6 0 Posted August 7, 2006 hi people, im trying to get my mk2 vr6 going i have got no spark and it is not fueling. now i have tracrd out lots of wires from the coilpack to the ecu and they all seem to be fine. (done a continuety test on them) also when the car turns over im getting a signal at the coilpack.. i have checked out the fuel relay and there seems to be no supply to it. tracing the wires out red & yellow go to the fuse block, but dont get any voltage from it? green & blue im unsure of(think it goes to the air mass meter) red & white i cant trace and white goes to the ecu. can anyone shead any light on what i need to do or if any one knows or has some wiring diagrams i could use it would be most helpfull. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 7, 2006 Has this car ever run?? What year VR is it - ie does it hav an imob? Have you VAGCOM'd it? Quote Share this post Link to post Share on other sites
volkswag0nvr6 0 Posted August 7, 2006 yea it was running till i had a short in the wiring loom. but that is all repaired now. found i can get it to spark and the lift pump working by putting a feed to the fuel pump relay. i have found it has got the k jet tronic pressure pump underneath but not getting any fuel past that. should i be running this system? Quote Share this post Link to post Share on other sites
volkswag0nvr6 0 Posted August 7, 2006 ok its running now Quote Share this post Link to post Share on other sites
volkswag0nvr6 0 Posted August 7, 2006 i needed a feed to the fuel relay so i wired a new one in and hey presto she started, just need to get a few bits sorted for the mot now.. took it down the road for a test and i had forgotten how fast it is.. might have to sell the corrado now. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 7, 2006 Nice one dude! Quote Share this post Link to post Share on other sites
