arj 0 Posted August 8, 2006 Hi all I'm a newbie here. Can someone please advise on a problem that has defeated my local garage for about 2 weeks now. The car which my wife now uses all the time suddenly cut out at a set of lights after it had been running for about 1/2 an hour on a very hot day. When I went to the rescue I magaged to start it briefly but the engine soon stopped again and wouldn't rev, even under no load. My local garage who gave serviced the car for the last 10 years recovered it. The time this occured coincided with it's annual MOT and service so I said fine sort the fault out and do the rest at the same time. Two weeks later and they can't diagnose the fault and the car has only cut out once (whilst running at the MOT station for the emissions test). They have been running around in it locally and even left it running for an hour but to no avail. The car has been fitted with a new ignition switch a couple of years ago and a new fuel pump about a year ago. Here's hoping someone can help as she loves the car and despite it getting a little tatty round the edges she loves the car and doesn't want to part with it. Regards Andrew Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 8, 2006 Hi Andrew and welcome to the forum... I'd change the fuel pump and ECU relays anyway as they are cheap and will fail at some point but the most likely cause would be the hall sender starting to break down which is part of the distributer altho It could be other things like the coil itself, dodgy tank of fuel etc... Quote Share this post Link to post Share on other sites
