Nick
Quick question
Trying to re-align my clutch.
Ive bought a clucth alignment tool, and have used it, in what i think is the correct way, but just wanted to double check before i put it all back together.
The idea is to get these two bits lined up perfectly...correct?
so it looks like this...?
Basically, yes. Once you bolt the friction plate and cover loosely onto the flywheel then you use the alignment tool to centre the friction plate between the two. If you look at the 'nose' on the friction plate it should be centred within the pressure plate fingers. Then tighten up the bolts.
Hope that makes sense.
