Dub Style
Vr6 clutch on a G60 engine
Hello all on behalf of my mate who has a g60 and is currently looking at changing the gearbox, firstly is the mk 3 golf gti 16v the best box for the G60 and is it a straight fit. Also i've heard of people running a VR6 clutch on the G60 but will it work with the valver box?
Don't know about the mk III bits but all the Corrado clutchs will fit the flywheel on all the engine types.
The VR6 Clutch is the best clutch for the G60 and is a straight fit. I'm not sure if the Mk3 16V gti is a straight fit but certainly the Mk2 is.
However which is best really is down to the driver!! I preferred having the 1st and 2nd gears out af a VR6 box put into my G60 Bax. But as I said it is a personal preferencde for the gear ratios.
If you do a search on here the ratios and this subject have been discussed EXTENSIVELY!!
