93corradoguy 0 Posted August 14, 2006 I got an engine error code about my secondary air injection system-open or short to ground. Couldn't find anything in the service manual but in the wiring diagrams i found that its connected to a fuse. Sure enough i checked all my fuses and there was one fuse that was blown. So i replaced it. But i still had the same problem. Same blown fuse again. Thru trial and error i found out that its only blowing when i start the car. If i put the fuse in after i start the car it won't blow and the car runs fine. However, without a working fuse the car runs very choppy and will stop working now and again(usually when i'm in rush hour traffic). So needless to say i'd like to fix it. Any ideas? Quote Share this post Link to post Share on other sites
TIMMYVR 0 Posted September 19, 2006 Stupid thing to ask mate but there is obviously a surge through that fuse, but was the original one you replaced of the right rating according to the manual? Quote Share this post Link to post Share on other sites
