Dr Forinor 0 Posted August 20, 2006 Right, my cold air feed fell off not too long after I fitted it, I kind of assumed I hadnt tightened it properly and proceeded to fit it again and this time made sure everything was as tight as could be. It fell of again and I have figured out why. The cold air feed seems to be catching (you can actually hear it on hard cornering - circled in blue). I tried to push the BMC further back so it wouldnt catch as much and then tighten it properly (circled in red) but it still moved within the bracket, it wont grip enough (not matter how tight it is) and it still slides. Has anyone else had this problem? Anyone have any suggestions as to what I can do? I really do want (need) this cold air feed as I can tell the difference without it. Please help... :( Quote Share this post Link to post Share on other sites
craziscot 0 Posted August 20, 2006 Dr, I ended up bending the cold air feed straight and then bending it into a shape that suits the space to install it. Only other difference from the way I fitted mine, to yours, is I used the full length of (not very technical description) that piece of mecano, and bolted it onto the top of the suspension turret, there is already a bolt in there. Ran it under the connector cable for the MAF and then to the BMC with the clamp higher up the body of the canister, this has resulted in the mount being bent into tension a little, which seems to give almost no movement. Hope this helps. BTW excellent group buy, well worth the money in my opinion. Quote Share this post Link to post Share on other sites
Dr Forinor 0 Posted August 20, 2006 Hhhmmm, unfortunately I cant use that method anymore since I have already shorten my piece of "mecano", lol, but thanks for that advice. Anything else I can try? And yeh, I love the BMC too, very happy with it Quote Share this post Link to post Share on other sites
RADO.001 0 Posted August 21, 2006 i dont have this fitted to mine, dose it really make that much differance? Quote Share this post Link to post Share on other sites
Taggart 0 Posted August 21, 2006 Just screw through the end of the ducting into the BMC. And my meccano went down into a hole where the the CC holder was attached. Can imagine the engine vibrations would shake anything loose! Quote Share this post Link to post Share on other sites
Dr Forinor 0 Posted August 21, 2006 RADO.001: The bracket or the cold air feed mate? xbones: Thats fine about screwing through the BMC for the ducting, but it still catches and you can hear it, I'd rather it didnt catch either, which brings me back to my point of how do i get the BMC to sit a little further back and stay there now? Any idea if I can get a hold of a "standard sized" mecano piece? Will try fixing it to the turret instead. Quote Share this post Link to post Share on other sites
Taggart 0 Posted August 21, 2006 Don't attach it to the engine would be my suggestion! Quote Share this post Link to post Share on other sites
Dr Forinor 0 Posted August 21, 2006 Don't attach it to the engine would be my suggestion! Erm, hence my last question Quote Share this post Link to post Share on other sites
Taggart 0 Posted August 21, 2006 Something similar must be available from hardware shops. You've removed the CC holder... just fix it there. Quote Share this post Link to post Share on other sites
Dr Forinor 0 Posted August 21, 2006 Fix it there, ie drill a hole in the metal that surrounded the CC? Quote Share this post Link to post Share on other sites
Taggart 0 Posted August 21, 2006 Nah, use one of the bolts that secured the CC holder, and just use one of the holes. Quote Share this post Link to post Share on other sites
Dr Forinor 0 Posted August 21, 2006 D'OH!!! Damnit, I should have done that in the first place, eejit! Thanking you muchly :) Quote Share this post Link to post Share on other sites
Taggart 0 Posted August 21, 2006 Even if people keep the CC, I think you can still use bolt to secure the CC and the BMC. Quote Share this post Link to post Share on other sites
Dr Forinor 0 Posted August 21, 2006 Right, Halfords had some crappy flimsy bracket thingy and B&Q have a bracket which wont even bend slightly, so thats those ones exhausted. Shall try Homebase but I doubt they'll be any better. Quote Share this post Link to post Share on other sites
Taggart 0 Posted August 21, 2006 Car boot sale for some proper meccano? :D Quote Share this post Link to post Share on other sites
Dr Forinor 0 Posted August 21, 2006 Hehehehe, sounds like that might be ideal. Shall give Vince a ring and see if he can help me out or recommend something, cos truthfully that piece supplied is perfect, I shouldnt have butchered it, idiot that I am. Oh well, live and learn eh, lol. Quote Share this post Link to post Share on other sites
Guest Posted August 21, 2006 Just put my cold air feed on Sunday, I ended up taking the hole intake pipe off up to the throtle body and puting the cold air feed on and shaping it as I was securing the pipe back on to the TB Lost that induction roar now but can tell the performance increases, more so on the motorway but what a great piece of kit. Quote Share this post Link to post Share on other sites
RADO.001 0 Posted August 22, 2006 sorry, i meant the cold air feed mate? Quote Share this post Link to post Share on other sites
Dr Forinor 0 Posted August 22, 2006 Well I noticed a clear difference between have the cold air feed on and off. Its definitely quieter (which I dont like as much as without it) but definitely more responsive. I reckon you give it a go and see what you think yourself mate. Quote Share this post Link to post Share on other sites
RADO.001 0 Posted August 23, 2006 well ive been thinking bout putting in a directional cold air feed, rather than conecting it onto the BMC it will just provide a stream of cold air across the area around the BMC intake. if that makes any sences!? Quote Share this post Link to post Share on other sites
Taggart 0 Posted August 23, 2006 But you won't get a stream at low speed, when you need it. When you're going fast, there's quite a lot of cold air churning about anyway. Quote Share this post Link to post Share on other sites
Dr Forinor 0 Posted August 23, 2006 well ive been thinking bout putting in a directional cold air feed, rather than conecting it onto the BMC it will just provide a stream of cold air across the area around the BMC intake. if that makes any sences!? I see what you mean, but why do that anyway? Why not just connect it up? There's no extra benefit of not connecting it up. Or is there? Quote Share this post Link to post Share on other sites
RADO.001 0 Posted August 24, 2006 well im hoping to keep the noise that my C makes without conecting directly to the BMC but still feed it as much cool air as i can. Quote Share this post Link to post Share on other sites
DanA 0 Posted August 24, 2006 I've just used a short piece of the ducting and slotted it behind the headlight where the OEM filter gets its air from... Seems to work really well and saves messing about with the CC. Still makes a good amount of induction noise too! Quote Share this post Link to post Share on other sites
Dr Forinor 0 Posted August 24, 2006 well im hoping to keep the noise that my C makes without conecting directly to the BMC but still feed it as much cool air as i can. See your point, well give both a go and see what fits you best? Quote Share this post Link to post Share on other sites
