Nick
x-threaded bolts
There are 8 studs that attach the exhaust manifold to the block. It appears that 3 of 8 studs wont 'grip' or 'screw' once in the block, so im assuming that it has been cross threaded, but personally ive never come across this due to lack of diy practice. lol.
I bought some new studs, but it appears that its actually inside the block bit has de-threaded.
Any suggestions, as im buggered?
I do have a welder friend coming to help tomorrow, and suggestions so far is to either weld the stud in place (:shock: - seems like a bad idea?!) or try and re-thread the block, but then id need different, larger studs, and would need to enlarge the manifold hole too.
Sorry if ive jibbered on a bit. Im crap at descriptions.
Nick
helicoil is one option. it involves putting an insert into the hole once drilled out bigger and screwing into that. like a wall plug.
you could try and find some bolts with tapered shoulders going to a bigger thread or smaller shaft on the stud
I would go with the helicoil option as they are well easy to fit and are rock solid if done correctly.
Worked a treat on my head where the belt idler mech is (quite soft aluminium)
About £25 for the kit (including drill bit, tap, inserts and tools)
