lamwagon 0 Posted August 29, 2006 just found out that my g60 rear calipers are fooked, and was wondering how hard it is to fit mk4 calipers and also will i be able to use my g60 discs and pads as i have just brought some new brembo discs and pagid pads. cheers Adam Quote Share this post Link to post Share on other sites
Trig 0 Posted August 29, 2006 Hardest bit for me was getting the old caliper carriers off as they were seixed on. Aprt from that it was easy. Quote Share this post Link to post Share on other sites
peteTDI 0 Posted August 29, 2006 do you use the same handbrake cables ? or longer ones? Quote Share this post Link to post Share on other sites
dinkus 10 Posted August 29, 2006 All you need is Mk4 rear callipers and some Mk2->Mk4 Goodridge adapter hoses and off you go. You can use the standard Corrado pads, but apparently you get the best brake feel with Mk4 ones. Otherwise, the handbrake cable is the same. Quote Share this post Link to post Share on other sites
Trig 0 Posted August 29, 2006 Aye but you have to get the carrier off if you want to put new discs on, that was the hard bit for me! :lol: Quote Share this post Link to post Share on other sites
DanA 0 Posted August 29, 2006 Aye but you have to get the carrier off if you want to put new discs on, that was the hard bit for me! :lol: Yep, make sure you have an angle grinder at the ready! Quote Share this post Link to post Share on other sites
lamwagon 0 Posted August 30, 2006 cheers lads very helpful off i go 2 find my mk4 callipers. Quote Share this post Link to post Share on other sites
STORM 2 0 Posted August 30, 2006 If you get stuck with the caliper carrier bolts (like I did) use IRWIN BOLT GRIPPER sockets - fantastic! Quote Share this post Link to post Share on other sites
lamwagon 0 Posted August 31, 2006 ok mate cheers Quote Share this post Link to post Share on other sites
