quicky1980 0 Posted August 30, 2006 When my window is down and i close the door i hear a bang so i had a quick look inside the door and noticed that the window was hitting the doors reinforcment bar. should there be something to stop this happening? Quote Share this post Link to post Share on other sites
CharlieHorse 0 Posted August 30, 2006 Mine does something similar. More like a loud clicking noise. Not looked at why yet. Whos got a new mac then? Quote Share this post Link to post Share on other sites
Niges16V 0 Posted August 30, 2006 I think everyones does that now. I changed the little white plastic rollers which stopped the rattle but still get the glass/bar contact when shutting the door. I reckon it's the rubber glass guides on either side, probably not a servicable part so it would mean a complete window mechanism change. Quote Share this post Link to post Share on other sites
quicky1980 0 Posted August 30, 2006 Think i found out the reason My drivers door is VAG glass and has a guide glued onto the the glass itself The door glass that bangs is non vag and is missing this guide which i assume helps to stop the banging. Will put a guide on there as soo as i know which adhesive to use Quote Share this post Link to post Share on other sites
Deluk 0 Posted August 31, 2006 quicky i see you have a 2.016v like me and you have fitted g60 brakes, what did you need to change them ? Thx Deluk Quote Share this post Link to post Share on other sites
quicky1980 0 Posted August 31, 2006 i had a g60 setup from my last car (golf mk2 gti 16v). all you actually need is the g60 carriers and discs. You should use G60 callipers and pads but there arent any problems if you dont you just loose a little extra brake pad depth. hope that helps pm me if you need more info Quote Share this post Link to post Share on other sites
quicky1980 0 Posted August 31, 2006 Search the use. good advice but tried that before i posted, maybe look at making the search engine a little more reliable Quote Share this post Link to post Share on other sites
Jim 2 Posted September 1, 2006 No offense but the search engine works fine - you just have to know how to use it. You can't just stick words in there as by default it will search for all instances of that word... if you want search for a string of words together, you need to put the word AND between each one. I never struggle to find what I need to be honest. Quote Share this post Link to post Share on other sites
Deluk 0 Posted September 1, 2006 Sorry.... :( i will look more Quote Share this post Link to post Share on other sites
quicky1980 0 Posted September 1, 2006 No offense but the search engine works fine - you just have to know how to use it. You can't just stick words in there as by default it will search for all instances of that word... if you want search for a string of words together, you need to put the word AND between each one. I never struggle to find what I need to be honest. I know about all the short cuts to search ie " AND OR NOT etc" but i get a little annoid when i keep being told to use the search when i already have, possibly i have missed a match to my problem but if thats the case maybe a link would be more usefull Deluk this convo about searching is not aimed at you btw. Quote Share this post Link to post Share on other sites
