Dixxy 0 Posted August 31, 2006 ABS fault code displayed with VAG COM... 00793 - Brake Pedal Position Sensor (G100) 35-00 I understand i'll find this little baby under the brake servo... Does anyone know any way of testing the sensor for faults?? Should i be able to test with a multi meter?? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 31, 2006 Is the ABS working or not? If so I'd clear the fault and wait for it to re-appear before worrying about it Quote Share this post Link to post Share on other sites
Dixxy 0 Posted September 1, 2006 The story is that the abs light came on and found fault with the front left sensor. I cleared that fault and drove round the block, the fault instantly re-appeared. I replaced the front left sensor.. cleared any faults shown on VAG COM and took her out for a spin. ABS light re-appear... this time showing the fault at the top of this tread. I've cleared the fault and have a spin this weekend. Just trying to see what my troubleshooting process is gonna be if the fault re-appears. Not sure if the ABS is currently working haven't tried it. Quote Share this post Link to post Share on other sites
Dixxy 0 Posted September 4, 2006 I'm i right in thinking that the full version of VAG COM provides troubleshooting steps following each error code??? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted September 4, 2006 Dixxy said: I'm i right in thinking that the full version of VAG COM provides troubleshooting steps following each error code??? It just provides codes and measuring blocks if any,if you disconnect the brake pedal switch do you get the same code? Quote Share this post Link to post Share on other sites
Dixxy 0 Posted September 4, 2006 not really had the chance to look at it yet mate but i'll try that for sure. Quote Share this post Link to post Share on other sites
