Storm_Man 0 Posted September 5, 2006 I don't know if anyone can help without seeing or listening to it, but having driven it home tonight I noticed that after I turned the engine off (as well as the normal clangs and ticks) there was a liquid noise. It sounded like the sound you get when water drips into a metal bucket???? Also, the steering can be very heavy. I've checked the fluid and the level is fine but on some 90 degree corners you really have to pull the wheel. On others it's Ok...ish. The top end of the engine has been rebuilt and the chap who I bought if off, said that the steering has been the same since the engine rebuild???? Any ideas?? welcome back to the fold Storm_Man Thanks - I've missed it! Quote Share this post Link to post Share on other sites
amdmad 0 Posted September 5, 2006 power steering pump problem? is the fluid the right color? not black i hope Quote Share this post Link to post Share on other sites
quicky1980 0 Posted September 5, 2006 noise could be the exhaust contracing and making a pinking noise. steering could be due to slipping PAS belt Quote Share this post Link to post Share on other sites
Storm_Man 0 Posted September 5, 2006 The troulbe is, I have no idea whatsoever when it comes to mechanics of a car. I want to learn, but my knowledge is very basic! Do you think its worthwhile taking it to a garage and finding out what the faults are and then for me to use the 'search' tools in trying to rectify the problems???? Quote Share this post Link to post Share on other sites
Niges16V 0 Posted September 5, 2006 Check the obvious first - PAS belt, it may be slipping. I think you should only have about 10mm movement on the longest run. I guess you know where the pump is? If not, it is the thing bolted to the front botton left (or drv side) of engine, you have to get to it under the bumper in front of wheel. My wifes Golf intermittantly lossed the PAS when it was wet, the water spray caused it to slip and loose power causing the steering to go heavy when you needed it most. We were all novices once, you just need the confidence to have a go and to know when not to! Quote Share this post Link to post Share on other sites
