lindy33 0 Posted September 6, 2006 hi, i started my g60 last night and it started as usual straight away, then i had to stop it for a second then it would not start, the fuel pump is running , the plugs are sparking but no fuel is getting injected , i tested the volts at the injector rail and there is nothing, anyone got any ideas what activates the injectors, i recently put a sns stage 5.5 chip in it, is it possible its gone wrong? any ideas would be appreciated. thanks Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 6, 2006 Have you got an imob fitted? Where were you measuring voltage? Quote Share this post Link to post Share on other sites
biggrim 0 Posted September 6, 2006 Check the ecu fuse relay. Think it's third form the left at the top of the main fuse box. Quote Share this post Link to post Share on other sites
