Nick
Alternator
Could someone please tell me where the alternator is connected to?
Preferably with pics. :D The wires attached to the alt, i just cant remember where it goes... :scratch:
Cheers,
Nick
^^^^bump.
I know it goes to the starter motor, but there are a couple connections and im not sure exactly where they go.
Also, how is the alternator spring tensioner attached? If someone could spare 5 mins to take a pic, i will gladly return the favour/buy a beer.
Cheers,
Nick
I presume talking about a spring tensioner you must have a G60!
The thick power cable is to the starter motor, there is one other connection which is a thin wire which is the ignition light that connects to a single pin connector plug near the starter motor (blue wire, big black plug on the end that then disappears into the wiring loom.
The spring tensioner attached to the alternator/bracket via a bolt with 2 threads on it one either side of a hex head.
Pic from EKTA Attached - the part highlighted is what you need and if you havent got one then the part number is opposite!!
