cmoth
7 ignition leads for VR6
Can someone please tell me where the 7th lead goes that comes with a new set of ignition leads, I cannot find the existing lead at all?
Do I need to undo anything to reveal it?
Thanks
Col
Hello, the 7th lead will be the king lead that goes between the dizzy cap and coil...
As you can't find where it goes I assume you have a 93 onwards VR6 with a coilpack (a block of plastic with the 6 connections) so you don't need it...
Basically you've been sold the wrong set of leads...
That answers that then , thanks!
Are you saying the other 6 leads are not right then, as they seem ok and car appears to be driving well with them?
Its a 94 M, so definately coilpack.
Col
thats cool. They dont have numbers on them for the cylinders, I just made sure that I did one at a time and measured each lead against the new one.
Im using the Beru ones which Im led to believe are what VW use anyway.
Im hoping my car will be cured now as cylinder 5 did not appear to be fitted properly as practically came off in my hands, which I hope was the cause of the car going into limp mode ( again!)
Col
