Baz2004 0 Posted September 17, 2006 Replaced the oil recently and im now getting a flashing water light for some reason. Checked the water level and its fine overfilled it a bit even to rule out any low levels. It could be an air lock as the car has been sitting up 2 weeks but after burping it a couple of times when hot the light still comes on. Its coming on about 2 mins after startup and stays on flashing. I’m tempted to drive on with it but is a bit concerning having a flashing light on the dash when driving. Any ideas? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 17, 2006 Probably just a knackered sender in the tank mate - just co-incidence that it happened after the oil change. Quote Share this post Link to post Share on other sites
cymru-corrado 0 Posted September 17, 2006 GSF tanks are prone to dodgy level sensors, if its a vag one then could be dead and prob worth replacing cap if its a black one to. Quote Share this post Link to post Share on other sites
Baz2004 0 Posted September 18, 2006 New cap old tank. Might have a look at the sensor a the weekend. Quote Share this post Link to post Share on other sites
blackcat 0 Posted September 18, 2006 I have this on my golf. The water light flashes some days, some days it doesn't. The water level is always fine. I keep an eye on the temp and that is always fine. Can't really be bothered to sort it out. Quote Share this post Link to post Share on other sites
Corradokid135 0 Posted September 18, 2006 I have the exact same thing in my 90. i also checked everything and it all is fine. just another corrado problem haha Quote Share this post Link to post Share on other sites
chubbybrown 0 Posted September 18, 2006 Try banging the dash. The old mk1 used to do that and its dry joints on the dashboard lights. I used to bang it and it would go off :norty: Quote Share this post Link to post Share on other sites
Yash 0 Posted September 18, 2006 Sorry to hijack this thread but funnily enough this problem started on my rado this weekend. From reading posts on here it seems that the sensor in the header trank cant be replaced (correct me if i'm wrong) so think the header tank will need to be replaced. £14.50 from GSF or £7.88 from ECP,isnt too bad but seeing as cymru-corrado has said GSF ones have dodgy sensors may have to go to the stealers. Anyone know how much they are from VAG? Anyone have any experience of the ECP ones or are they the same as GSF? Quote Share this post Link to post Share on other sites
Jim 2 Posted September 18, 2006 Its not alien for VAG ones to die either.. the one on my mates 3 year old Golf anniversary suffered the same fate.. and that had only done about 40k! Just random readings warning about lack of coolant, etc despite a nice full expansion tank. Just got a new one in the end from VAG. Fairly sure they're not much more than they are from GSF/ECP... Quote Share this post Link to post Share on other sites
Baz2004 0 Posted September 18, 2006 Is there any way of testing the sensor? Id rather be sure it’s the problem before going to the trouble of replacing the fluid and getting a new bottle. Quote Share this post Link to post Share on other sites
Yash 0 Posted September 20, 2006 Baz2004, were you able to test the sensor? Quote Share this post Link to post Share on other sites
Baz2004 0 Posted September 21, 2006 Not yet does anyone know what readings I should be looking for ? What to test it with etc? Quote Share this post Link to post Share on other sites
