blackboy VR6 0 Posted September 17, 2006 Hello all, ive just got a 95 M plate black VR6 corrado, it starts first time in the morn when cold but it seems the hotter the car gets, the worse it is for starting, occasionally when flawing the car it has a little splutter while going up the revs, any help would be gratefull, on either problem cheers phil Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 17, 2006 Welcome to the forum! When was the fuel filter last changed? Do you hear the pump running on after you turn the engine off? Also - is there pressure in the fuel tank when you undo the cap to fill up? Quote Share this post Link to post Share on other sites
eatthis 0 Posted September 18, 2006 i had this problem on my obd2 vr try cleaning the throttle body with carb cleaner Quote Share this post Link to post Share on other sites
blackboy VR6 0 Posted September 18, 2006 just got the vr so dont know when the fuel filter was replaced (but will get it done of this could be part of problem) cant hear the pump run on after turning off, and no there's no pressure from the cap when i fill up Quote Share this post Link to post Share on other sites
Guest Posted September 18, 2006 Try the fuel pressure regulator. Had the same problem on mine a few years back. Starts fine from cold, and also when hot if you start it almost immediately after stopping, for example, stopping for fuel. But when left for an hour or so, it would really struggle to start, and would only fire up after turning it over for 5 or more seconds. Replaced the fuel pressure regulator, and cured the problem straight away... Quote Share this post Link to post Share on other sites
