Scansaver 0 Posted October 3, 2003 Hi we have 2 products that are new to the UK market And both are at a special price at the moment ProDiag for Palm PDA Shade Tree Software's ProDiag is a VAG 1551/2 compatible vehicle diagnostic tool for VWs, Audis, Seats and Skodas. ProDiag let's you do everything you can do with a VAG 1551/2. Creader VW/Audi The Creader is a pocket-sized unit designed to enable professional automotive technicians or DIY car owners to quickly and easily read and clear fault codes Reading fault codes Clearing fault codes Covering: Engine,Automatic Transmission,ABS and Airbag http://www.scansaver.co.uk Any questions please email us or post on the Corrado Forums Quote Share this post Link to post Share on other sites
Scansaver 0 Posted November 16, 2003 ProDiag 1.06 is now available. Some PalmOS 5 devices are supported, including the Tungsten T series and Zire 71. More ECUs to choose from. More fault codes for new vehicles. PIN support (7-digit codes). Improved ECU connectivity. Improved adaptation user interface. Scroll lists with Sony jog wheel and Palm 5-way controller. Pop-up keypad for entering numbers without Graffiti. Select which ECUs are scanned when adding a new vehicle definition. Updated User's Manual and vehicle data are also available Quote Share this post Link to post Share on other sites
W3RKD 0 Posted November 16, 2003 does this work with ipaq 3850 ? Quote Share this post Link to post Share on other sites
Scansaver 0 Posted November 17, 2003 Im sorry but your Ipaq 38500 will not work as it uses Pocket PC 2002 as it's Operating system ProDiag needs a Palm based Operating system Quote Share this post Link to post Share on other sites
W3RKD 0 Posted November 17, 2003 ok cheers for the prompt reply... Quote Share this post Link to post Share on other sites
