aposegil 0 Posted October 4, 2006 Hello all This first VR swap ive done into a LHD G60 damm not like the 4 pot vw engines lol First off all didn’t have any dash lights or fuel pump but that’s been sorted now two wires I forgot to plug in But everything turning over perfect but im not getting any spark. Im picking up the OBD1 wire to plug into the car (im assuming I can still read error code via the G60 port?) But I have power at the ECU and power at the coil pack (think both blue wires) but anything else I can test? Also there are three wires between the negative and positive wires for the coil pack. Im assuming this three are triggers for each bank, so are they negative triggers or positive? also tried a def crank sensor and still no difference. anything anyone can tell me I would be happy especially if uve done a vr conversion thank you in advance Quote Share this post Link to post Share on other sites
aposegil 0 Posted October 5, 2006 anyone? also to help its a coilpack 93 corrado this engine came out off Quote Share this post Link to post Share on other sites
