LowG
Wow R32 TT !!!
Ya seen this thing,does 0.60 in 3.2 secs video
http://www.kwsuspensions.com/r32/HPA_R32_TT.wmv
2003 Golf R32 TT by HPA
POWERTRAIN/CHASSIS
Drivetrain layout Front engine, All Wheel Drive Hatchback
Engine type 15° V-6, cast-alum block/head
Valve gear DOHC, 4 valves/cyl, variable valve timing
Bore x stroke, in/mm 84.0mm x 95.9mm
Displacement, ci/cc 3200CC
Compression ratio 7:1
Max horsepower @ rpm 545 @ NA (intake temp of 50°-60°C)
Max torque @ rpm NA
Specific output, hp/liter 170.31
Power-to-weight, lb/hp NA
Max engine speed, rpm 7200
Transmission 6-spd manual
Suspension, front; rear KW Inox Coilover system
Brakes, front; rear 13.1-in vented disc, 10.0-in vented, cross drilled
Wheels, front; rear 18x8 BBS RC
Tires, front; rear 225/40ZR18 Dunlop SP Sports
DIMENSIONS
Wheelbase, in
Track, f/r, in
Length, in
Width, in
Height, in
Curb weight, lb
Fuel capacity, gal
TEST DATA
Acceleration, sec
0-30 mph 1.01
0-40 mph
0-50 mph
0-60 mph 3.2
0-70 mph
0-80 mph
0-90 mph
0-100 mph
1/4 mile, sec @ mph 11.4 @ 121 (tested)
Top speed, mph 212
Braking, 60-0 mph, ft 107.7
600-ft slalom, mph 70.9
200-ft skidpad, lateral g 0.881
CONSUMER INFO
On sale in U.S. January 03
Base price $31,000 (est)
Price as tested $50,000 (
uh and just found thats with 19 psi of boost but can be tweked up to 30psi of boost :shock: :shock: i guess the 4 valves per cylinder work really well with a couple of kk's turbos,we talking supercar performance here as it goes head to head with Ferrari Enzo. Simply amazing for a V dub to get up there with the big boys!! :D
