nia573 0 Posted October 11, 2006 What are the symptoms of a failing inner cv joint? I’ve had to replace the outers before as they are quite easy to diagnose with the clicking sound they make under load, but I haven’t had to change an inner one before. I’ve got a faint rumbling sound under load & when freewheeling that to me either sounds like a failing bearing or inner cv If they need replacing, once the inner splined bolts have been removed, will I be able to drop the driveshaft down to get the inner cv off (do they just knock out or is there a circlip holding it onto the shaft??), or will I need to undo the outside driveshaft nut & balljoint to allow a bit of room? Quote Share this post Link to post Share on other sites
BeavisJem 0 Posted October 11, 2006 you will need to undo the driveshaft bolt on the hub to give you enough room. There is a circlip holding the driveshaft on. Just need to undo the 8 splined bolts. Beavisjem Quote Share this post Link to post Share on other sites
