EXPAT
New here need help
Hi all, New here, but not to Corrado’s had a G60 when I was living in Florida about 9 years ago and have just picked up a new to me 2.0 16v to use as a daily driver over in Switzerland as my Wrangler is getting expensive to run. I need to prepare it for the Swiss equivalent of the MOT that is on the 8th of November. At the moment other than replacing the clutch (toast) the middle silencer and rear silencer the only thing baffling me are the Reverse lights. When I stick it in reverse they will not come on or do but you have to fiddle with the gear stick to keep them on. Anyone have any idea how to fix it.
Thanks
BTW great site. :D
Hi there, welcome to the forum.
You'll find that alot of problems you'll come across have been discussed on here before, it's allways worth trying the search feature.
Here's a couple of threads I found to get you going, I put 'reverse AND lights' into the search :
http://the-corrado.net/.archive/forum/viewtopic. ... rse+lights
Hope that helps.
theres a black plastic cover on top of gearbox 2 ten ml bolts hold it on if you undo it take it of theres a metal tube bolted to the selector check to see if its come loose usually the problem good luck
