chez2165
G60 Chip
I was wondering if someone could give me details of where to buy a SNS G60 chip from.
And also is there any way of finding out the boost pressure without fitting a Boost gauge.
Use the search man, it's really your friend, and you'll 8 times outta ten find the answer to commonly asked questions like these using this function !
Anyways, here's the info you require, you can buy SNS G60 chips direct from the UK-SNS tuning (Bilal) rep at:
http://www.snstuning.co.uk/
How to test your boost levels - UK spec cars
1. Start Engine
2. Move the MFA selector to "2"
3. Press and hold the MFA end button (keep holding)
4. Stop engine
5. Start engine
6. Release the MFA end button.
7. Press the MFA End button one time.
You should now see 450-800 readings fluctuating with idle. Anything higher than 800 is not right (vacuum leak). Much less than 450 is probably too much timing advance.
Go run your car!!! 3rd and 4th gear to REDLINE. Carefully note the highest #'s you've got.
A pullied charger should not make less than 11.6psi, and even so, thats weak. A Stock charger should make ~~11psi in perfect shape!
EURO Hg(#'s of boost/vacuum) Comments
200 -23.7
400 -17.8
600 -11.9
800 -5.9
1000 0 (Atmosphere- ala no boost, charger is bypassed)
1200 2.9 psi (Your charger is dead or big boost leak)
1400 5.8 psi (Your charger is about dead or big boost leak)
1600 8.7 psi (Your charger needs new apex strips or big boost leak)
1800 11.6 psi (Great for stock pulley, Probably needs new apex strips if 68mm pulley)
2000 14.5 psi (Great for 68mm pulley on stock charger)
2200 17.4 psi (Great for 68mm pulley on heavily ported charger, hold on to your ass fast!!) Rambo
2000 and up folks need to be careful with fueling, as the programming maps end at about 2000 on the ecu Smile Dynotuning, and air/fuel/egt gauge, and custom chip recommended
Cheers and HTH
Cheers BigTartanJudge.
I'll lock this thread up as your questions have been answered :)
