VRTrickster
Should I of run my cams in?
Ive just read an article on installing cams on the Puma Racing website, and it says that when you start the car you should not let it idle and keep the revs up. I'm just wondering If I may of caused my head damage due to not carrying out a bedding in procedure?
Does it really affect things that much if you don't carry out the bedding in process? Reading this has concerned me a bit!
http://www.pumaracing.co.uk/cam1.htm
The camshaft bearings (plain white metal) should be given gentle treatment for a few hours running - say no more than 3500rpm for a couple of hundred miles. But the cams and tappets are hardened steel and should be ok right from the word "go".
Best wishes
RB
