DanVW
G60 Crankshaft replacement
Hi All,
I need to replace my crankshaft as my G60 has just chewed through the Crank pulley (again :mad: )
Can anyone tell me if I replace it with a second hand Crankshaft can I replace the bearing shells, Thrust washers with new VAG parts or should I fit the ones that match the donor crank shaft? And will I need to do anything to the donor crankshaft to match it with my lightened + balanced flywheel?
Obviously I will replace the bearing cap bolts for new ones along with oil seals both ends and clutch bolts (as it will be coming off)
Also is there anything else I should replace while I am in there (did the oil pump on Wednesday :roll: so that should be ok)
Cheers all
Dan
I've got about 3 spare PG and KR valver crankshafts i'm binning,you interested?,only problem is that i'm based in Rome...
And they are all perfect,never broke a crank bolt on all my engines.
