dom 0 Posted October 25, 2006 engine mounts has any one changed there engine mounts just found out the car i just bought as not got long on engine mounts before it drops out what will it cost :( Quote Share this post Link to post Share on other sites
Taggart 0 Posted October 25, 2006 engine mounts what engine mounts have you got in why will your engine drop out what kind of engine is in your corrado Quote Share this post Link to post Share on other sites
dom 0 Posted October 25, 2006 my corrado is a 18 16valve guessing they are just standard Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 25, 2006 http://www.vwspares.co.uk/corrado_other.php :wink: Quote Share this post Link to post Share on other sites
dom 0 Posted October 25, 2006 cool thanks any idea on cost spent most of money buying it got a mk2 golf gti that turned into money pit :( Quote Share this post Link to post Share on other sites
Taggart 0 Posted October 25, 2006 Click on the link. Look at the prices. Use a calculator ;) You can change yourself easy enough. Quote Share this post Link to post Share on other sites
Kick Up The Rs 0 Posted October 27, 2006 Just done the rear one on my G60. The worst part was actually separating the Lamda bracket from the mount. I ended drilling the old nut out due to corrosion. O/S front on an axle stand. Slackend the two big bolts underneath first. Remove air box for better access. Using trolley jack, carefully lift engine to take weight off the mount (I lifted the engine on the rear engine mount bracket). Whip out old one, slide in new one, fit bolts, remove jack & do it all up nice & tight. Feels very tight now...! Quote Share this post Link to post Share on other sites
