Supercharged Junkie
C/L problems
Hi
Got a weird problem with the central locking, the doors unlock when you press the unlock on the alarm but after anywhere between 2 to 10 seconds the doors lock themselfs ?.
Looking at them yesterday and when i pushed the door pin down on the passenger side only that door would lock, went over to the drivers side pushed the pin down and all the doors locked, so thought ahhhhh found the problem tried the passeneger side again and still didn`t work so went back to the drivers side and guess what that now didn`t work :mad:
Strange thing is it would still lock/unlock on the alarm!
Anyone had the same/similar problem? Got passat door handles which have been on there for 4months, but had to disconnect some wires going to the original handles, would this have anything to do with it you think? even though the c/l has been working fine since i changed to passat handles?
Its a strange one, is there a c/l controller some where in the car?
Don`t think its anything to do with the pumps, seems more electical related because it doesn`t always do it, only started Sunday!
Any help would be great
Thanks
Ian
http://the-corrado.net/.archive/forum/viewtopic. ... 952#593952
Nah, cheers VR6 couldn`t find it when i looked for the damn thing :-(
Still no closer to an answer thou :sad: surely someone might know whats going on
Petty sure its electrical related now, tried hold the door pin up and it still tried to lock itself, seems if you let it lock about 3 or 4 times then it will stop locking :mad:
very strange problem, might try getting hold of a passenger side actualtor and see what that does, anyone know how much they cost?
