Supercharged
BBM 8v Billet Fuel Rail
Hi, has anyone fitted one of these with the standard FPR and FPR adapter and had problems with the regulator leaking where it meets the rail?
O ring is in good condition but the edge can still be seen when the fpr is tightened up into the adapter - this is making it weep ever so slightly and you can also hear it when the pump primes...
i have one on mine mate i used a bit of hylomar on the o rings had no probs with sealing at all. i used a new o ring maybe a slightly thinner one might help?
Make sure everything is seated Squarley in the recess's and there should be no sealing problems at all. I have not had to use any smaller 0-rings/sealing compounds in the past to ensure a leak proof seal.
on second thoughts i didnt use hylomar after all knew i had to get some that day but was for the rocker cover prob just a knackered o ring if its been nipped.
