latestarter2
heater motor resistor? replacement
been told the reason i can only get the heater to owork on level 4 is the resistor??? has gone on the heater motor?..was told it was a simple job to do just involves removing the panel under the glove box..is that so and does anyone have a pic i can look at so i know what i'm supposely doing?...cheers
Yup easy peasy 10 min job, just make sure you pay close attention to which way round the resistor is as well as the path it takes as there are a couple of important earths on its tracks
aahh...that would suggest still ample opportunity for an easy peasy 10min job to turn into a bloody infuriating 4 hour grind hurling abuse at the car if past experience is anything to go by!!...lol
:lol:
One thing you need to watch is that it's quite easy to blow the heat fuse when soldering, Maplins sell a heat shunt, which is like an alloy spring-loaded, clip-on tweezer thing that diverts the heat, just clip it onto the fuse and it'll stop it blowing. Makes a fiddly job a load easier. Use a multimeter to check that you've not screwed up before and after the soldering.
Worked for me :-)
Indeed that will make it easier, the fuse is rated up to about 190*c. mine was ok without the heat shunt and i did have the iron on it for a relitivly long time
I guess it depends a bit on how competent you are at soldering - mine is best described as shocking borderiing on criminally bad...
