quicky1980
After market coilover springs, not set!
My cheap coilovers dont lower enough so I was wondering can you get the springs from somewhere which enable the car to sit lower and wont have drop out problems? Something like jamex springs which have helper springs
So the threads on the damper bodies don't go down far enough, or are the springs are too long?
Easiest way would be shorter springs and helpers but if you're going lower than the intended minimum height of your kit, you could bottom it out regularly, so maybe try some 'tuning' helpers, which are a lot stiffer than normal ones.
where can i get the shorter springs and dampers? I'll cut and rethread the rod to avoid bottoming out.
what are tuning helpers? are tehy like the normal helpers but just stiffer?
thanks
